921B circuit question
- analogmonster
Hi owners, technicians and other knowing people, one can find three trim pots within the sync part of the circuit, one is labeled "Phase Lock Offset" in the service manual (the one which adds a voltage to the OTA output IC13, zero adjust I assume), one is located between the outputs of the 796 Balanced Modulator (100r) and one (10k) which adds a negative voltage at the summing node feeding the sync (Q5). In the service manual adjustment location diagram of the 921B one can find two sync related labels, "Phase Lock Filter Cutoff" and "Phase Lock Filter Balance" beside the previously mentioned "Phase Lock Offset". Does anybody know which trim pot is what and how they have to be adjusted? Thanks in advance, Carsten
Newest Track: https://soundcloud.com/analogmonster-1/chill-y
Analogmonster: https://www.analog-monster.de/index_en.html
Re: 921B circuit question
The 10k trimmer appears to be the phase lock filter cutoff in the service manual by looking at the pcb traces on the 921b board. I would assume that the phase lock filter balance is the 100r which it seems to be by also looking at a picture of the board. I'm not sure how you would set them though. Sorry for the late reply if you've already figured that out.
- analogmonster
Thanks for your reply. What you say is what I assumed according to my understanding of the circuit diagram, and you confirmed that now, so thanks again for your analysis.WZOLL wrote:The 10k trimmer appears to be the phase lock filter cutoff in the service manual by looking at the pcb traces on the 921b board. I would assume that the phase lock filter balance is the 100r which it seems to be by also looking at a picture of the board. I'm not sure how you would set them though. Sorry for the late reply if you've already figured that out.
