My troubleshooting thus far (not necessarily in this order and often times tried multiple times):
1) No matter the combination of notes I set in the Analog Keys or the Voltages set, all I got the Minitaur to do was to play back the before mentioned high and low note.
2) Experimented with Pitch V/oct and Pitch HZ/V with same results
3) Reinstalled the MiniTaur FW (using 2.1.5)
4) Tested the MiniTaur via MIDI. No problems there
5) Under the Minitaur Editor I found the various CV Calibraion sysex commands. I ran them according to directions, though I am not sure if the Minitaur is actually receiving a 1V / 4V as it is not responding to pitch in any way. I reset it back to default DV calibration as well
6) Power cycled the Mintaur and Keys several times with the same results.
7) Swapped and tested cables, no issues there.
9) Googled the issue... seems like the Minitaur has a lot of CV issues in general, but at least people are getting pitch
I am a CV noob so there could be operator error somewhere along the line and would be happy is this was the case. That said, I was able to CV the Sub 37 with no issues and I think I have done my due diligence at this point.
Is there something else I should be trying?
