MiniMoog to Minitaur CV
sub guy
Post by sub guy » Tue Jun 27, 2017 9:25 pm
Hey I hope this is not a question for which there is no answer but to make fun of me, :oops: but shouldn't this work for playing the Minitaur using CV from the Monimoog? Pitch CV out on the MiniMoog into the Pitch CV in of the Minitaur, shouldn't I be able to play note for note this way?
Kirneh Ness
Re: MiniMoog to Minitaur CV
Post by Kirneh Ness » Sat Jul 01, 2017 9:49 am
sub guy wrote:Hey I hope this is not a question for which there is no answer but to make fun of me, :oops: but shouldn't this work for playing the Minitaur using CV from the Monimoog? Pitch CV out on the MiniMoog into the Pitch CV in of the Minitaur, shouldn't I be able to play note for note this way?
I am not super well versed in all this (still learning). I have a Minitaur, but no D. Anyway, this should definitely be possible, but you need to have 'gate' triggered in the Minitaur. So use 'gate' from the D into the 'gate' on the Minitaur as well. Then it should work. I am eager to hear if it works.
Guitars. Moog Grandmother, Labyrinth, DFAM, Spectravox, Subharmonicon, Minitaur, Slim Phatty, Moogerfoogers 101, 102, 103, 104M, 107, 108M, and CP-251. Yamaha CS-15. Roland JUNO 106. DSI Tetr4. Korg ARP Odyssey Module Rev1. Dreadbox NYX 2.
ummagumma
Post by ummagumma » Sat Jul 01, 2017 4:14 pm
does gate include pitch info? I thought it was only a trigger?
OP could probably use MIDI to hook the minimoog up to the minitaur too, I believe
what does the minitaur manual say about CV in?
stiiiiiiive
Post by stiiiiiiive » Sat Jul 01, 2017 5:53 pm
GATE only holds trigger information.
PITCH CV holds the continuous pitc information.
Both are needed for playing a synth from another because the slaved synth need to know what pitch its oscillator(s) should be set to, and when to trigger the envelope(s).
I think gate and CV formats are the same between the Minitaur and the Model D; indeed the manuals will tell more accurately than me :)
sub guy
Post by sub guy » Sat Jul 01, 2017 8:14 pm
stiiiiiiive wrote:GATE only holds trigger information.
Im going to have to look into it when I get more time. I finally got the midi info figured out and am now running the Minitaur with the Model D via midi. When last I tried though the CV approach was not working I was just getting the same high note out the the Minitaur no matter what key I hit on the Model D.
Kirneh Ness
Post by Kirneh Ness » Sun Jul 02, 2017 11:05 am
sub guy wrote:I was just getting the same high note out the the Minitaur
I got that as well the first time I tried cv (using an external cv source). I managed to get tones instead by calibrating via firmware. I know it is a vague answer, but find calibration in the settings, and then you should be able to calibrate the Minitaur's available notes to incoming cv. In theory it should definitely work :D
