Sub37: Noise from keypress with filter at 0?
Everything Phatty.
thomasmooger
Post by thomasmooger » Tue Dec 13, 2016 2:48 am
Is it normal to hear the noise of audio noise when pressing a key (init preset with the filter at 0)?
oli@sub37
Re: Sub37: Noise from keypress with filter at 0?
Post by oli@sub37 » Thu Dec 15, 2016 5:51 am
No filter does completely shut off the signal. At the lowest setting, the Filter cutoff is at 20Hz with the higher frequencies attenuated by 6/12/18/24dB per octave depending on the filter setting. So there's still audio coming through, but at a rather low level. Or maybe you hear a filter click because of the Filter Envelope?
Bass Player and Synthesist.
Voyager RME #1273 | Sub 37 #8490 with SSQ37 Update | Virus TI2
Mac OS X 14.7 | Cubase Pro 14 | MainStage 3 | RME UFX+
stiiiiiiive
Post by stiiiiiiive » Thu Dec 15, 2016 10:26 am
… or maybe you’re hearing the noise of the VCA letting the electronic life out.
Charming analogue :)
thomasmooger
Post by thomasmooger » Thu Dec 15, 2016 5:53 pm
oli@sub37 wrote:Or maybe you hear a filter click because of the Filter Envelope?
stiiiiiiive wrote:… or maybe you’re hearing the noise of the VCA letting the electronic life out.
It sounds like very soft pink noise, not a click, but like opening up a gate when pressing the key. Is that normal?
stiiiiiiive
Post by stiiiiiiive » Thu Dec 15, 2016 6:38 pm
It the volume of the said noise follows the amp envelope, then I would say it is the electronics behind the VCA.
I've already heard that. It's analogue, mate, it's alive. Plus it won't be noticeable when your oscillators are on (or will it?...). Don't worry, play music :)
thomasmooger
Post by thomasmooger » Thu Dec 15, 2016 9:08 pm
Thanks :) I was worried that something may have happened during shipment, because the box arrived with some damage.
