Problems with syncing to daw. Please help
Everything Sub.
mucktone
Post by mucktone » Thu Nov 17, 2016 2:24 pm
Ok. This is going on 2 months now that I've had this problem and I can't seem to get it straightened out. Please bear with me as I attempt to word this properly. When I create a new sequence with my Sub 37 it works fine until I try to sync it with ableton. It syncs ok as far as the timing goes, but the positioning of the sequence seems to be locked in with the meters in ableton.
For example: There are 20 notes in the sequence. When I start the sequence at the beginning of bar 1, it starts on note one of the sequence. So far so good. But I want to start recording the sequence on the third bar of the song by pressing the space bar when record enabled. But when I do that it starts on the 13th note of the sequence. No bueno. If I start the sequence on the secon bar it begins the sequence on the 17th note. If I start it on the 11th bar it begins playing on the 1st note again. I don't want to have to shift all of my tracks forward or backwards any time I decide that I want to try to throw a sequence into the song after I've already started writing it. This does work but is inconvenient. I've been able to do this on the past but i must have made some sort of change that I didn't mean to and this was the result. I apologize if I have left out any vital information and will provide it if needed. I'm not to great with midi as you can tell and I'm guessing that it has something to do with that, either with my moog or within ableton. It's definitely not as fun using my moog since this happened, and I would really like to get back on track. If anyone can help with this, please do. Thank you
OS X 10.5 Yosemite, 64 bit
Ableton Live 9
Sub 37 Tribute
Midas Venice F32
Matthias32
Re: Problems with syncing to daw. Please help
Post by Matthias32 » Sun Nov 20, 2016 7:19 pm
Not sure if this is any help,
but in the preferences-midi tab of abltn live
you can change the midi clock format that is going to that particular device from 'song' to 'position'
also on the sub when you press midi you get general midi options on the little display, scroll down to the 'clock options' tab. There might be a setting there that could help
Sub37,Minitaur,DSIProphet12,Cubase,AbltnLive,Reason,RMEfirefaceUCX +FocusriteOctopreMKIIDynamic, BabyfacePro,LaunchpadPro,AkaiMpk249,ZeroMkII,StrymonBigSky,ShermanFB2, Xbase09,TR808,PF500 Stagepiano, ElCapistan,HeddType07,Mics &Waay too many cables
