I have the opportunity to get a Liberation and searching on the forum I could not find answers to all the questions I have. Plus I’ve read this and that here and there and am not sure at all of… anything. So here am I with a list of points I’d like to shed light on so that the next guys have a place to go a gather most of the answers from.
First of all, from the pictures I looked at, I could see the panel is very much like the MG1’s. That being said, I’ve read that the synth is closer to the Prodigy. Is that a fact, and why is that? I expect it to sound just as the MG1 (except it has separate envelopes for amp and filter and triangle wave and square/pulse are allocated to oscillators the other way round…)
On the MG1, the polyphonic part is not affected by the modulation. Is that so on the Lib? Don’t the LFO and pitch ribbon affect those cute organ waves' pitch?
Second, I’ve read (or understood) that it had an optical keyboard trigger system. Is that right?
Is the keyboard a high note priority one as on the MG1 ?
I’ve understood that the associated rack unit is all together the power supply and the place for audio out. Are there any other things to be found in there? CV connections? Audio In? Others?
The unit I’m interested in has a DIY rack since the original one was stolen back in the days. It has been made by a famous synth tech so I’m quite confident (read on…)
Does anyone know how much the Liberation weighs? Ah, no, I got this one: 14 pounds (6.4 kg approx..) for the keytar alone, and just half of it for the power unit alone.
The seller says his Liberation “needs some maintenance because there seems to be a problem with keyboard contacts; the pitch is not stable and gets better when the unit is warm”. I feel the problem may come from oscillators rather than keyboard, maybe from the rack… Any clues?
Are there any specific points I should inspect on a Lib? I would check each command, key, plug, but maybe some particular test would be clever…?
Any other point I should be interested in/ aware of?...
Thanks in advance
