Voyager LCD Screen
RL
Post by RL » Sun Mar 05, 2006 7:35 am
so I can implement 'this' without taking the hardware(x-tra sound banks)?
Sure, Bob said the software should work for both version and I did it 8)
just
Post by just » Sun Mar 05, 2006 7:36 am
just
Post by just » Sun Mar 05, 2006 7:50 am
And this 3.2 upgrade is due to come...?
also think the recall function is a realy handy x-tra.
jamirokid
electric blues
Post by jamirokid » Thu Jun 22, 2006 6:18 pm
My screen when blank/all black and it was a biatch to find the contrast function in the dark. I'm running 3.0 right now. Should I upgrade to 3.2 for sure? What about storing my patches? Will they transfer. I have the editor but I hear it doesn't work right with 3.2. Is this correct? I would like to get the bug fixed cuz I gig with my mme and I dont want to have to fix it mid set!! Please help.
Josh
GregAE
Re: electric blues
Post by GregAE » Fri Jun 23, 2006 7:57 am
jamirokid wrote:My screen when blank/all black and it was a biatch to find the contrast function in the dark. I'm running 3.0 right now. Should I upgrade to 3.2 for sure? What about storing my patches? Will they transfer. I have the editor but I hear it doesn't work right with 3.2. Is this correct? I would like to get the bug fixed cuz I gig with my mme and I dont want to have to fix it mid set!! Please help.
Josh
Josh -
You should upgrade to OS 3.2. Your patches will be fine, but I'd recommend archiving them before you do the upgrade just in case.
I assume your comments are about the Macintosh version of the Editor. There were a few problems with the Mac version, but SoundTower has fixed this in V2.01 and everything seems to be working fine.
Here are the details (copied from the SquareWave site):
SoundTower has posted an update to the Macintosh version of the Voyager Editor. This update (v2.01) has fixed the two issues reported by members:
1. Load User Bank files - You can now load your saved User Bank (.mvr) files.
Note: The .mvr file will always load into the bank it was saved from. This is important for those with the Voyager's expanded memory option. For example, if you save Bank A, that .mvr file will go back into Bank A when you load it. For this reason, you should add a bank designation to the file name:
Example: My_Bank_A.mvr
2. The WRITE command now works correctly independent of the USE LOADED DATA checkbox status.
The Editor update is available here: www.soundtower.com/moog/update2
Also, go to the SquareWave site and download the latest Voyager OS Menu Reference Page. It's a very handy resource and would have been a big help to you for resetting the Voyager display contrast 'blind'. You can find it here:
Files/Voyager Reference Pages/OS 3_2 Menu Reference.zip
Greg
Widge
Post by Widge » Mon Jun 26, 2006 7:19 am
This is really weird - my Voyager with 3.0 software has just done exactly the same thing while I was saving a sound.
All the sounds are there, but the screen is completely black and you can only make out the lettering by viewing it from the far left of the screen. However I tried the fix that was suggested, but I don't appear to have LCD contrast anywhere on the Master Menu so that doesn't work. So is it an upgrade to 3.2 or nothing then? Advice would be most appreciated!
Martin Orford
Widge
Post by Widge » Mon Jun 26, 2006 8:07 am
Now I'm completely confused. I've loaded OS 3.2 with no problems, but the LCD screen is still black (although still backlit). But Master 1.1 isn't "LCD Contrast" on my machine, it's MIDI Run Status. So anyone have any ideas where I can find the LCD Contrast now?
Martin Orford
GregAE
Post by GregAE » Mon Jun 26, 2006 12:28 pm
Widge wrote:Now I'm completely confused. I've loaded OS 3.2 with no problems, but the LCD screen is still black (although still backlit). But Master 1.1 isn't "LCD Contrast" on my machine, it's MIDI Run Status. So anyone have any ideas where I can find the LCD Contrast now?
Martin Orford
It's under Panel Mode, menu item 2.4 - LCD Contrast
- Greg
Widge
Post by Widge » Mon Jun 26, 2006 1:10 pm
Thanks Greg,
That's great, my LCD is now fine again.
All the best, Martin Orford
