Stomp Box Pedals that Work With Synths (Digital, Analog)
Re: Stomp Box Pedals that Work With Synths (Digital, Analog)
While saving for a Strymon combo Big Sky + Timeline....I am having great fun with a BEHRINGER ECHO MACHINE EM600 and the Valhalla plugins via Ableton....actually many time I am asking to myself if I truly need the Strymons (but I love them!)
"...A fatal attraction is holding me fast
How can I escape this irresistible grasp?.."
@ollimac73
did you run synths into the Behringer? What is your view on the hardware (since we are focusing on pedal/stompboxes in this thread)?
Minimoog Model D / Moog Little Phatty TE / DSI Prophet 08 / Elektron Digitone / Elektron Octatrack Mkii / Clavia Nord Wave / Nord Drum II / Clavia Nord Lead 3 / Roland TR-707 / Roland TB-03 / Korg MS-20 / Access Virus TI 2 Polar / Roland SH-101 /:mrgreen:
For what it costs...the Behringer Echo Space is a great pedal, a must have.Spitfire wrote:@ollimac73
For a Live setups, I will wait the Strymons...but at home, to give a nice flavor to my Sub37, I love it.
For 30 something GBP you cannot go wrong
Ollimac73 wrote:For what it costs...the Behringer Echo Space is a great pedal, a must have.Spitfire wrote:@ollimac73
one more thing - how is the signal to noise ratio on it? do you feel that you have to do a lot of attenuation on the synth's end to not overdrive the pedal to the point that if you have good volume coming out of the 37 you'll get some nasty ratchet-sounding noise coming out of the pedal?
Here are my experiences with some guitar pedals with various synths.
Retro-Sonic chorus clips past 1/4 volume level on all my synths. Such a drag because of signal to noise ratio issues downstream for recording and playing live but it sounds so good when its not clipping.
Effectivy Wonder Juno Chorus clips past 1/2 -2/3 volume level (white noise level depending on synth)
EHX Clone Theory clips past 1/2 volume.
EHX Poly Chorus clips past 1/4 volume.
EHX LPB 2Tube Stereo Tube Preamp Pedal reduces bass frequencies (really mid focused)
Catalinbread Belle Epoch reduces bass frequencies
Gurus Amps Echosex 2 was fabulous, wish it had multihead echoes
Mr. Black SuperMoon and Double Chorus clips past 1/4 volume
MXR 70's Distortion
Boss RV-6
Pigtronix Echolution
Those are my favorit ones.
Boss RV-6
great topic! I already found some great stomp box pedals through this topic.
I'm still looking for a chorus stomp box pedal voor my voyager. Except the minifooger/moogerfooger, are there recommendations ?
- stiiiiiiive
The Boss CE-3 is an instant classic: BBD based, not wild at all. Will have your mono signal go stereo.
Another suggestion: if you’re planning to use a delay afterwards, or if you don’t want to increase your FX footprint too much, you can consider using a nice (BBD) delay that features modulation. Some good examples are EHX Deluxe Memory Man with or without tap tempo, EHX Deluxe memory Boy, Chase Bliss Audio Tonal Recall, Ibanez ES2 (did not like that one…), and some MF104 of course.
- thealien666
A footnote on BBD based delays, some of them don't work very well with synths that have a high harmonic content because at longer delay times, there might be some audible aliasing-type artifacts due to low clocking frequency. Some of the more expensive ones will have automatic integrated low-pass filtering on longer delay times, to remove such artifacts at the cost of darker repeats.
Modern digital delays don't suffer from that, and some of them emulate BBD analog behavior well enough. Strymon Brigadier comes to mind. But also Boss DD-7 (in analog mode).
Hey y'all. Sorry for stepping away for so long without refreshing the list on page one. I'm getting to this now... great feedback everyone!
@kurt2100 - Glad to hear this post has helped.
It ain't easy getting effects, so getting feedback from users is key.
SlurmsMacKenzie wrote:Here are my experiences with some guitar pedals with various synths.
You're the man, Slurms. This is exactly the kind of feedback (pun intended) I was looking for. Very helpful, since clipping/bad distortion is the main problem with these pedals when connected to synths, especially the EHX stuff from what I can tell.
Hi!
Can you recommend a good and inexpensive looper?
Voyager PE, VX-351, 2xCP-251, LittlePhatty SE II, MF-101, MF-102, MF-103, MF-104M, MF-105M, MF-107, MF-108M
- stiiiiiiive
Well, there is a whole spectrum of loopers out there, from the one-track-no-undo-single-footswitch one to the multi-track-with-integrated-mixer one.
Amongst the cheapest are the TC Ditto, Xvive D3, EHX 360 and Mooer MicroLooper.
Just a bit higher you'll find the TC Ditto X2, EHX 720, Boss RC1 and RC3.
To get back to the general topic, I've recently tried an EHX TurnipGreens with a LP and it works well. The TG is a box with a HolyGrail Max and a Soul Food, the later being a clone of the Klon Centaur. You can invert the FX chain direction as well as use the FX loop to place other pedals inbetween. No particular advantage over using the two pedals it embeds except maybe the footprint just a tiny bit smaller and the fact you can invert the direction on a switch move.
I bought it to see whether it could replace a combination of ProCo RAT + EHX Cathedral in a pedal board I use. I could, as long as I play in mono.
On a side note, reverb into overdive can seem a weird choice but I actually like the overall dirty quality of the obtained effect. If some of you guys like grit and unusually grainy, middy, NINesque soundscapes, try this combination
So, I tried having my SH-101 go into a new EHX Cathedral... big mistake. The impedance mismatch and my results after the level setting procedure was unsatisfactory. Far to audible noise, feedback... just an outright mess.
I returned it and got out of the idea of trying any EHX pedals with synths. The small clone was a similar disappointment. Instead, I went on ebay and bought for $200 a Lexicon MPX 1. Wow. Just. Wow. It's not a stompbox, so it won't be added to the list on page 1, but damn... what a great unit. To think: they actually went for over $1200 brand new, and mine is a 9.8/10 condition. It's like the previous owner never used it.
Anyway, I see that Stiiiiiiive may have had a positive experience with the Cathedral, so I won't dog it all the way. Me... no,the Cathedral just didn't get the job done at all.
I've been using the following with a moog voyager
Sansamp bass para driver in the mixer section sounds amazing
EHX poly chorus I have an old version and it works great I especially like the filter matrix I can manually get sweeps that way, and it does repeats similar to the memory man
Zvex lofi junky really great warble effect
EQD rainbow machine I love using this thing in small amounts
Greer amps peace maker got this recently and it sounds great on the synth I like to stack it with EHX germanium od
