Hi guys,
finally managed to get hold of a MP-201, which came without a psu. On buying and using this psu, i find the device is only powered when i move the psu tip with my finger.
please see attached video web link.
https://onedrive.live.com/redir?resid=3 ... ideo%2cMOV
My specific question is :Do you thing this problem is due to a faulty connecter within the mp201 itself? I know i could wedge it with something if all else fails.
All the best and thanks for looking
MP-201 psu problem
Re: MP-201 psu problem
Did you buy a Moog PSU or some other brand?
Stephen
Stephen
- _DemonDan_
Assuming that the power supply and its cable are operational and compatible, the culprit is probably the barrel connector.bethy1234 wrote:On buying and using this psu, i find the device is only powered when i move the psu tip with my finger.
While the OD (outer dimension) is probably OK, the ID (inner dimension) is probably too wide, making it difficult to make a good connection to the center pin without angling it a bit.
You can buy a replacement barrel from a parts shop that will fit more snugly.
_ _DemonDan_ _
