Volume Control
Volume Control
Is there a way to equalize all the volume levels on the Voyager? I am
using several sounds and I'd really like not have to continually adjust the
volume button, but rather have it all preset.
For instance, (I can't remember the preset #) Catherine of Aragon is very
quiet against some of the more bassy sounds. I really have to set most
everything to 50% voume, then when I use the CofA preset, I have to crank
it to 100%, then when I use some of the bassy stuff, I have to go to 40%.
My guitarist works the board, and it's driving him crazy, because every once
in a while, I'll forget to adjust the voume, and something will BLAST across
the PA. If I go into the panel display to see the settings for each CV, the
value of the volume display seems unaffected by turning that knob.
I've been playing with the Voyager since July, but I can still be considered a
newbie, so please go easy on me. Thanks!!!
Thanks for the input.
I went into the panel and assigned each volume control to be individual. We then took the 15 or so presets that we've come up with and worked with the volume control to get them in the range of the level that we need on a per-song basis.
I've also added a foot-controlled volume pedal, but it really helped not to have to play with the volume control by hand, since I'm playing keys/foot pedals and bass. One less thing to worry about was worth its price in gold.
