Step Sequencer doesn't play
Everything Sub.
MNordex
Post by MNordex » Sat Oct 17, 2015 8:37 am
I've recorded a step sequence in my Sub 37 just how it's decribed on the manuel and how it's done on a youtube tutorial. I can see on the screen that the steps seemed to be recorded but the sequence doesnt't play/work, it hangs on step 1. Is there something I have to (de)activate on the menu?
paul_sub37
Re: Step Sequencer doesn't play
Post by paul_sub37 » Sat Oct 17, 2015 8:42 am
Just a thought - do you have the arpeggiator rate set to SYNC but with no MIDI clock coming in?
My Sub 37 Patches - Sub 37 + Mother 32 + UR-44 + OS X 10.11/Ableton Live/Logic Pro X + Push 2
MNordex
Post by MNordex » Sat Oct 17, 2015 8:45 am
On the menu the clock options are standing to:
send clock: arp
send st/stp: on
folow spp: on
paul_sub37
Post by paul_sub37 » Sat Oct 17, 2015 11:25 am
I meant if the SYNC button next to the Arpeggiator rate knob was on/lit then it will wait for external MIDI clock to play the next note in the sequence.
If you don't have some other device sending MIDI clock to the sub 37, the sequence won't play with SYNC on.
MNordex
Post by MNordex » Sat Oct 17, 2015 11:56 am
I've tried it with the sync on and off but it still doesn't work.
paul_sub37
Post by paul_sub37 » Sat Oct 17, 2015 12:13 pm
Quick sanity check: the ON/REST light next to the PATTERN knob is lit?
Also, check in GLOBAL MENU 2.1 that you don't have GATE set to STEP ADV in the CV MAPPING MENU as that would wait for a trigger input before advancing the sequencer.
MNordex
Post by MNordex » Sat Oct 17, 2015 12:27 pm
Res / on button is lit and the gate is set to default.
MNordex
Post by MNordex » Sat Oct 17, 2015 12:34 pm
I found it: in the cv mapping menu (2.1) the volume was set to ST1 RSET. I've changed that and now it works. Thanks for your replies, that is why I could find the solution in this menu :D
paul_sub37
Post by paul_sub37 » Sat Oct 17, 2015 12:39 pm
At least you've solved it and this thread might help other people who have the same problem :)
MNordex
Post by MNordex » Sat Oct 17, 2015 12:48 pm
:D thanks
