SUB 37 MIDI CC OUT to ABLETON ENVELOPES
Everything Sub.
bs44
Post by bs44 » Mon Sep 21, 2015 1:52 am
Hi, not sure if possible but seems like it would be . . .
What I want to do:
Record the MIDI CC automation data from the MOOG Sub 37 into Ableton's MIDI clip automation/envelopes.
Example:
If I turn the filter cutoff knob (#CC 19) on the Sub 37, I want it to actually change the MIDI clip's envelopes in Ableton Live.
I can manually input the MIDI clip automation in Ableton which sends the data to the Sub 37 perfectly (see Image), but wondering if I can do the opposite and turn knobs on the Sub 37 and record the automation into the MIDI clip's envelopes in Ableton?
Hopefully that makes some sort of sense.
Mac Pro (2013), MAC OSX 10.10.5, Ableton Live 9.2.2, Moog Sub 37 firmware 1.1 via USB.
jsharpphoto
Re: SUB 37 MIDI CC OUT to ABLETON ENVELOPES
Post by jsharpphoto » Mon Sep 21, 2015 10:04 am
do you have "track" and "remote" active in the midi preferences, for ins and outs of the sub 37 in the ableton preferences?
Moog Format Modular
Model D (2016)
Moog Subsequent37
Oberheim OB-6
Sequential Rev2
jaycoffman
Post by jaycoffman » Tue Sep 22, 2015 3:28 pm
Yep, it's possible to do this for all controller lanes (except CC8 - LFO2 which is a bug being fixed). Like jsharpphoto says, make sure the MIDI i/o is setup correctly… watch out for feedback loop (turn local control off). I'm not at my rig at the moment, but if you still have trouble i can snap you my i/o.
Mac OSX 10.10.5 (64-Bit) | Ableton Live 9.5 (64-Bit) | VST / AU | Sub37 + MF-104
Jay Coffman | coffman.jay@gmail.com
WesWook
Post by WesWook » Thu Feb 11, 2016 9:30 pm
I'm working on a sub 37 max for live device and noticed, via midi monitor, that the multi drive knob is sending cc #18 and cc#19. Is this a bug or working properly? Seems a little odd to me, thanks!
Tonejammer
Post by Tonejammer » Fri Mar 04, 2016 3:23 pm
Hey man - keep us posted on the max for live device - sounds good!
tigre25
Post by tigre25 » Fri Mar 18, 2016 3:58 pm
Is your problem already solved?
Minimoog Model D Vintage 2016, 2x Moog Sub-37, Rhodes Fender MK II, Hohner Strings Melody, 2x SIEL Orchestra 2, Arturia 88, Oberheim OB3 Rack
Ableton, Focusrite, Steinberg, Macbook Pro
