Well, we can't change the Filter CV, and the Gate CV can only be mapped to an on/off function.... so what are your favorite things to map the Pitch and Volume CV's to?
I really like to send a step sequencer to the VCA Release, with a sync'd arpeggiator. I'm a sucker for variable release times.
Discuss.
Favorite Sub37 CV Mappings?
Moog Format Modular
Model D (2016)
Moog Subsequent37
Oberheim OB-6
Sequential Rev2
Model D (2016)
Moog Subsequent37
Oberheim OB-6
Sequential Rev2
Re: Favorite Sub37 CV Mappings?
55 views and no responses. Did you guys not know you could remap the inputs? Or is talking about your settings considered insider trading?
Moog Format Modular
Model D (2016)
Moog Subsequent37
Oberheim OB-6
Sequential Rev2
Model D (2016)
Moog Subsequent37
Oberheim OB-6
Sequential Rev2
Would love to check out a recording of this, I'm curious about the interesting sounds you can get from different cv mapping combos!jsharpphoto wrote: I really like to send a step sequencer to the VCA Release, with a sync'd arpeggiator. I'm a sucker for variable release times.
Discuss.
I'm a fan of mapping the filter decay. Always adds a great deal of variation to a sequence.
http://www.soundcloud.com/variar Retrowave music
Sub37, Minikorg700s, Maxikorg800dv, Eps16+, Roland D50, Dx7, An1x, Korg Poly61, Paia9700s, Korg Ds8, Micron, Shruthi1
Windows 8.1 64bit, Ableton 9.1, Vsts, Scarlett 18i8, Pot of coffee
- _DemonDan_
Mapping one of them to RTCHT CT (Ratchet Count) is a bunch of fun.jsharpphoto wrote:So... what are your favorite things to map the Pitch and Volume CVs to?
Just toggle RATCHET to ON for most or all of your Sequence's Steps.
Now, sweeping an external controller will make your steps Ratchet anywhere between 1 and 8 counts in real time.
In PRESET EDIT, you can got to (PRESET EDIT 1.2) SEQUENCER / MOD DST (Seq Mod Destination) and set it to: AEG REL.jsharpphoto wrote:I really like to send a step sequencer to the VCA Release, with a sync'd arpeggiator. I'm a sucker for variable release times.
Now, the Seq Mod value (stored for each Step) will modulate the Amp EG's Release Time.
Make sure the SEQ MOD AMT is a non-zero value.
Then, experiment with the ARPEGGIATOR (PRESET EDIT 1.1) GATE LENGTH, which will significantly alter the effect of varying Release Times for each note.
Obviously, this is not the same as having a separate Arpeggiator and Step Sequencer; but it will allow you to have a Sequencer with separately-crafted Amp EG Release Times per Step.
_
_DemonDan_
_
