midi to cv conversion using VX351?
Hi!
Can you use the voyager as a simple midi/cv converter? If you trigger the voyager using midi, is gate and CV signal sent out of the VX expander?
Re: midi to cv conversion using VX351?
Absolutely! The VX-351 will output key pitch and gate CV's in response to MIDI inputs (try it!).kcabdeef wrote:Can you use the voyager as a simple midi/cv converter? If you trigger the voyager using midi, is gate and CV signal sent out of the VX expander?
Greg
Sounds great! One thing to keep in mind: Some Korg synths repond to exponential CV's (V/Hz) instead of linear CV's (V/oct). I think you'll be fine, however, since I'm pretty sure that the Korg Mono/Poly is a V/oct design. Check the specs to be sure.kcabdeef wrote:I don't have it yet, but just got a mono/poly and I'm looking for a midi/CV for it. Now I'll get a super one.
Good luck!
Greg
- analoghaze
There are far cheaper ways than using a Future Retro or a VX-351. One possibility:analoghaze wrote:I use a Future Retro 777 to do this. It works great.
www.synhouse.com/midijack.html
-G
GregAE wrote:Sounds great! One thing to keep in mind: Some Korg synths repond to exponential CV's (V/Hz) instead of linear CV's (V/oct). I think you'll be fine, however, since I'm pretty sure that the Korg Mono/Poly is a V/oct design. Check the specs to be sure.kcabdeef wrote:I don't have it yet, but just got a mono/poly and I'm looking for a midi/CV for it. Now I'll get a super one.
Good luck!
Greg
It's V/oct. The MS20/10/50 are the ones using V/Hz. thanks anyway!
ahh, don't wreck my excuse to buy the VX...GregAE wrote:There are far cheaper ways than using a Future Retro or a VX-351. One possibility:analoghaze wrote:I use a Future Retro 777 to do this. It works great.
-G
But they are not that good in tracking over more then 3 octaves.GregAE wrote:There are far cheaper ways than using a Future Retro or a VX-351. One possibility:
The quality of the D/A and the analog parts does not appear to be that good for this low price tag.
What, me, burst your bubble? Not gonna happen!kcabdeef wrote:ahh, don't wreck my excuse to buy the VX...GregAE wrote:There are far cheaper ways than using a Future Retro or a VX-351. One possibility:analoghaze wrote:I use a Future Retro 777 to do this. It works great.
-G
While there are cheaper ways to get a MIDI-CV converter, if you already have the Voyager, the VX-351 is the best way to go, IMO. You not only get the MIDI/CV capability (not its main purpose, but cool that it can do this), you unlock a very powerful aspect of Voyager control.
- Greg
anyone use this with sh-101? (playing midi from voyager)
