So my Mini had to lose virginity as it had to be opened up for the first time.
After putting it on my living room table and after unscrewing the hundert billions of screws I plugged into the multiple outlet strip on the other side of my room and shaked some cables in the powerlight area as assumed to work again after. So I closed the unit and plugged into the strip of my Constellation setup again. DARK........
Having done this three times I was nearly about to freak out completely, but I said to me, FU** You guy, I`ll get you.
I plugged into the outlet directly into the wall.....and....LIGHT ON.............
I took the spray again and blew about one ton into the outlet of the strip and see.........LIGHT ON now permanetly..........
I have to mention that the Mini worked fine all the time without losing any function.
My tech is also pretty weird of all about this as he said the power light is set in parallel, so it s not possible what happened here.....
One other thing I discovered also, the tranny in the powerlight area wabbled to and fro. I tightened the screws but it`s still wabbeling as it is fixed on a metal bar and this bar is connected from the front side of the panel board.......FU** !, I`ve to live with, but it`s more silent again now.
Formarly when it went loud I gave the housing a flap and it went silent then.....for a while..........
I said to my tech, probably I have ghosts in my house........
