Minitaur power supply?? How many milliamps?
evannaculum
Post by evannaculum » Wed Mar 18, 2015 2:42 pm
researching some of the voodoo labs power bricks to power my pedal board. What are the power requirements for the minitaur? The manual says: 12v DC positive tip. 7 watts consumption. What is the milliamps requirement? I swear that the power supply that came with it is 12v 500ma, I'm going to double check when I get home. It seems to operate ok, although there is about a 3 second delay on power up. When I switch on the power supply, it takes about 3 seconds for the lights of the minitaur to flick on. Is that normal?
evannaculum
Re: Minitaur power supply?? How many milliamps?
Post by evannaculum » Wed Mar 18, 2015 9:58 pm
sorry i was tripping. the power supply is a 12VDC 1200ma. is that the required milliamps for this? 1200ma?
MC
Post by MC » Thu Mar 19, 2015 11:56 am
Minimum is 1200ma.
Blille
Post by Blille » Mon Feb 17, 2025 7:05 pm
I know it’s been forever but I couldn’t find this answer either so I’m bumping this thread so that others know.
The power supply is 1200ma but that doesn’t mean that is the minimum.
To calculate the current (in milliamps) for a 12V DC power source with 7W power consumption, use the formula:
I = P / V
where:
• P = 7W (power)
• V = 12V (voltage)
I = 7W / 12V = 0.5833A
Convert to milliamps:
0.5833A × 1000 = 583.3mA
So, the equivalent current is 583mA (or 0.583A).
Some devices have consumption peaks at startup but it looks like one can power the Minitaur with much less.
sszyszka
Post by sszyszka » Wed Apr 02, 2025 8:20 pm
Just check the label on the bottom of your unit. Mine lists 12v/250mA.
