subq wrote:feels the same actually the audio just doesn't drop out
mine wasn't loose or anything when I sent it in
I read an opinion elsewhere that the pots for the filter just weren't up to par and they corrected that...again, I don't know how true that is
however, moog support is awesome and if you have an issue they should take care of you
if your sub37 has the problem, you will know, basically, at a certain point in turning the knob it will just drop out and any slight movement in that area will cause the filter to cut in and out...so you won't get a smooth sweep turning the filter knob
Thanks again subq!
I think i'm just being paranoid after reading some of the posts and having a recent nightmare with a faulty Arturia minibrute.
I did send a message to moog support though (or at least I think I did it was to
info@moogmusic.com?)to ask about this 10 days ago but have not heard anything back! Maybe it is not the right address?
Really, really love this 37 though - truly a totaly different experience from using VST emulations as I have been doing for so long! The time just seems to fly by when I switch her on and I don't seem to get very far exploring any presets lol - I totaly forget to try any others out since I get so enchanted with tweaking one sound - it is pure enjoyment
