Fun with Chameleon
Fun with Chameleon
I was doing something else but found myself jamming with this unusual combination!
http://www.youtube.com/watch?v=IC2GlZY0Q70
Cheers
Cheers
Re: Fun with Chameleon
That was too cool!Filipe wrote:I was doing something else but found myself jamming with this unusual combination!
Cheers
I believe the ARP Odyssey bass sound was used in the intro of Chameleon...
Thanks for sharing.
Thank you. Yes, the bass was ARP Odyssey.SaussDigit wrote: That was too cool!
Thanks for sharing.
I kept the Minimoog on my left because it is such an authoritative instrument, specially for bass.
It can re-create almost every other analog synth bass, but the same cannot be said for the ARP (or any other). Just change filter poles, resonance, etc.
Cheers
Do you miss the extra keys when playing the Phatty with your right hand? Or the third oscillator?Filipe wrote: Thank you. Yes, the bass was ARP Odyssey.
Cheers
How do both instruments compare?
You did it pretty cool actually
Music is my passion. http://www.ahappyvalentinesdayimages.com
Not a difficult question, but the answer is not completely linear.SaussDigit wrote: Do you miss the extra keys when playing the Phatty with your right hand? Or the third oscillator?
First, the two instruments don’t compare. Sound quality, playability and versatility in programming sounds are vastly superior in the Minimoog, which is a matured musical instrument that stood the test of time.
Sure I miss the additional fifth interval. You can play three octaves if your song or segment is in F, F#, G, etc. but with a 3 octave C >> C you really have 3 octaves only if you are playing your part in C. If you change key to G (just as in my example) you use the high G in the line that goes down to a lower G that just is not there. You need to resort to inversions and mask the lack of keys. If you are thinking quickly (improvising live) that stress is not welcome, because you cannot imagine and just play. The fluidity of your playing gets lost now and then.
(just watch in which note a grand piano starts and ends). The more keys the better, if you can play.
For some purposes I needed 2 Minimoogs!
Also because of the sound. The 3 oscillator + capable filter set makes the difference in most situations. It makes your main voices so powerful and adequate; it gives you confidence like few instruments do.
The Phatty is a subset of the Minimoog. Having said that,
If I had the possibility of owning two Minimoogs, great.
However I might eventually buy a Phatty if I had the chance.
I am used to it now and I am rather fond of it; I use it to play music, not just experimenting with sound (the latter, nevertheless, is a legitimate use of the instrument as well).
Actually I don’t plan to sell mine. With the right patch and a little add-on it cuts through the mix with delightful texture and can compete with any screaming instrument (I had to lower it down almost 6 db). I has its own merit!
Chalhat: thank you, that was nothing much. Just having fun.chalhat wrote:You did it pretty cool actually
Cheers
So one actually needs one octave+, unless playing everything in CFilipe wrote: Not a difficult question, but the answer is not completely linear.
Are you using your own patches?
Do you see the Taurus as a sort of Minimoog with pedalboard? It gives you the possibility of consistent beating across the octaves...
Fun stuff!
Love Herbie and Chick.
So do I.EricK wrote:Fun stuff!
Funny as other stuff I used to like did not age well:
https://www.youtube.com/watch?v=44KkrH07A30
Cheers
On the Phatty I modified slightly one of the factory patches (changed its name...).
About Taurus, it seems a fortunate filter/amplifier coupling incident allows it to shake the house even before it reaches the speakers
The consistent beating helps dealing with amplitude holes in the sound that are particularly associated with long sustained notes.
Varying beating from note to note is not inherently bad, for instance the piano derives some of its distinctive timbre from that.
Also, there had been piano/bass guitar combined droning some years before the Taurus introduction:
https://www.youtube.com/watch?v=5tHUSiC ... d&start=59
https://www.youtube.com/watch?v=5tHUSiC ... start=1515
https://www.youtube.com/watch?v=Nvp553a ... &start=535
(Won't hear those properly with phones)
But when you consider the amount of resources that it takes to fairly reproduce the sound and convenience of a Taurus, you begin to understand why it developed a family of its own. And if your hands are busy...
(I will P.M. you my address just in cause you are tired of your Taurus).
Cheers
