Hi Gang,
While there may someday be even more ways to do this, the next Sub 37 update's CV MAPPING feature will allow you to use a Sustain Pedal in the GATE IN jack to control the OSC 2 ON parameter.
Depending on whether you use a Normally Open (N.O.) or Normally Closed (N.C.) pedal, you'll be able to turn OSC 2 ON or OFF at will.
This is a reasonable solution for those who don't want OSC 2 to join OSC 1 when you go from playing two notes to only playing one note. Simply use the Sustain Pedal to make OSC 2 sound only when you want it to.
If you don't already own one, now is the time to get a Sustain Pedal that has a N.O./N.C. switch, 'cause you're going to want one right after you install the next update for this and many other GATE IN destinations!
CV Mapping Empowers DUO Mode!
- _DemonDan_
_
_DemonDan_
_
Re: CV Mapping Empowers DUO Mode!
Great tip, Dan
Another cool thing I did was map Filter CV In to Filter poles and swept that with an expression pedal. Pretty damn cool.
- BrufordRules
I think CV mapping is one of the greatest improvements in the new firmware but, does anybody know if the CV to MIDI conversion works internally at 7-bit or 14-bit?
Thanks in advance.
Thanks in advance.
- _DemonDan_
I'm not at mine right now but, my guess would be that it depends on whether you choose 7-bit or 14-bit in the CC FORMAT parameter found in the MIDI MENU.BrufordRules wrote:I think CV mapping is one of the greatest improvements in the new firmware but, does anybody know if the CV to MIDI conversion works internally at 7-bit or 14-bit?
_
_DemonDan_
_
- BrufordRules
Thanks Daniel. That would be the best solution. I hope they clarify that in a future addendum document.
