Denim wrote:hm, I guess no.
Amos - any thoughts?
Don't mean to be unpatient here, but I've waited for a solution for 16 months now.
I cannot account for your results. I too am using Windows 7 64-bit (professional, SP1 if it makes a difference).
I am using the Moog USB MIDI driver with the Sub Phatty and it's working fine.
I can use the standalone Sub Phatty Editor and it's working fine; I can use the Sub Phatty Editor plugin and it's working, no "disconnected" message.
I just realized the plugin editor i'm using is v1.0.3... I'll test v1.1 again... it's working for me also. Tested in Cubase v7.5 and Live 9.0.6.
I don't know if I'm somehow failing to see something obvious that you aren't doing... I assume you can see and select the Sub Phatty as the MIDI in/out device in the Editor... are you seeing "Hardware disconnected" instead of the firmware version, in the lower left corner of the Preferences page, or are you seeing it somewhere else?
