New to the Minitaur, need help with my controller
Hey there! I bought a Alesis Q25 to control my Minitaur but even when I set the octave to the lowest setting I'm not getting a read and little sound is happening. It works fine with a Critter and Guitari pocket piano so it's a little weird that I'm having a hard time with the Alesis. Thoughts? Help?
Re: New to the Minitaur, need help with my controller
"Little" sound means you get any sound at all? And if you get a sound is it just too short or too quiet? If it is to quiet, my Minitaur OSC lvl and main volume knobs were set to minimum on default to prevent overload and damage on speakers when first used. So i had to "pump" up the volume. If the sound is just too short like a click or blip then maybe you envelop settings are set very short and you have to raise them? If you get no sound at all, i have no clue but to check if the cables are connected properly.
