Can't assign Filter Res to touch screen
Other parameters works just fine, but with filter res it's nothing. Tried tweaking the knob and there's signigicant change. Tried 25, 50 and 100%. Tried filer res and other parameters on both axis. In any cases everything works as it should except there's nothing happening when assigning to filter resonance. Restarted the Voyager as well. Any ideas?
Latest gigs
https://youtu.be/Fpvi7Jrq8DQ
http://youtu.be/owdKlBrUUKY
Minimoog Voyager EB & Minitaur + MF-101 + MF-103 + MF-104M + MF-107 + CP-251 + Minifooger Drive. MachineDrum UW + MonoMachine + Rickenbackerbass (-75) + Hagströmguitar (-75).
Re: Can't assign Filter Res to touch screen
I've been assigning area of touch to resonance for a long time, it can be done.
Good to hear. Any ideas of why I can't?MC wrote:I've been assigning area of touch to resonance for a long time, it can be done.
Latest gigs
No ideas?
Latest gigs
I recall having the same issue, but I tried to reproduce it during the weekend and I couldn't.
I will check again tonight and post my results anyway.
http://audiotecna.info
Solved it! The problem was that Filter Res was already assigned to Touch Area. As soon as I assigned something different to that parameter Filter Res was free.
Latest gigs
HAH glad you figured it out I was actually going to tell you exactly this. took me a minute to get it tooMBlom wrote:Solved it! The problem was that Filter Res was already assigned to Touch Area. As soon as I assigned something different to that parameter Filter Res was free.
