Problem with VCO 2 & EG AMOUNT knob positions.
gsearle
Post by gsearle » Tue Apr 01, 2014 7:10 pm
Hi
The VCO 2 knob and EG AMOUNT knob are not behaving correctly.
When turning these two knobs on the hardware the editors gui knob movement is out of alignment with the actual hardware knob position.
As the hardware knobs position is almost fully turned to the left the GUI knob is just before 12 o'clock.
When the hardware knob is turned fully to the left, the editor GUI knob then jumps from just before 12 o'clock all the way fully to the left
Hope that make sense!
I've installed the V 2.1.0 firmware but that hasn't helped.
Really stuck with this one, any help would be appreciated.
Cheers
George
dshook
Re: Problem with VCO 2 & EG AMOUNT knob positions.
Post by dshook » Wed Apr 02, 2014 3:41 am
Hi George
Had this same problem with my MT -there is a knob/pot calibration sysex routine that you need to perform - you should be able to find it if you dig around the forum a bit here. Good luck!
gsearle
Post by gsearle » Wed Apr 02, 2014 3:55 am
Hey
I've sorted it!
ludacrisca
Post by ludacrisca » Tue Apr 22, 2014 9:45 pm
hey i where did you find it?
have the same problem
