Post
by Colonel Monk » Wed Apr 02, 2014 6:19 pm
I don't have a picture handy of the "rack" I built for my 6 foogers and CP using the MOOG rack brackets, but it's quite simple.
Two Vertical 1x4 Pine, with four 1 x 2 pine horizontal braces. One on bottom, two on the back, one on top. I spaced the racks as I wanted to have room for patching, and then I drilled pilot holes in the wood for #10 Pan Head sheetmetal screws.
I think using regular racks for Moogers in the long run is going to annoy you to no end. They are simply too heavy to lug around. They make sense for a mixing board, or a tube amp, but not so much here....
I know that Moog equipment is expensive, but seriously, you'd really have to blow it and drop down a flight or two of stairs to hurt them, so long as the knobs are protected.
A soft case that would fit my Rack would be awesome, but I get by with a Uhaul shipping blanket wrapped over the knobs and then I fix it in place with a few lengths of rope - when I need to move it....
I had planned to have a case made for the foogertron by Cabbage Cases in Ohio - I got a quote one time, I think it was $130 or so for the "LiteFlight" case, with some foam inside. These are the light ABS cases that usually have a top that fits over the bottom and a couple of straps with nylon fastex buckles.
I might still do that, but being a bass player with heavy cabs and ridiculous tube amps, the last thing I'm going to lug around and store is another anvil case.
Anyway, my rack started out with me using some scrap lumber in my shed, to still being my rack 10 years later. I have hung it on the wall next to my spot in rehearsal room, and I had leaned it against a wall from the top of my speaker cabs, or other anvil cases...
I'd consider doing something a little different if I only used them in my home studio, but at this point I still like to be able to take them with me.
I'd be interested in any other methods of transport you all use though.... If Gator or someone made a bag that fit my wood rack I'd be in heaven.
Monk
Colonel Monk
Slim Phatty, Foogertron 7000: Low Pass, Ring Mod, Phaser, 104z Delay, ClusterFlux, Bass MuRF, FreqBox, CP-251
2X Mother 32, Minitaur
