Voyager or Modular
Re: Voyager or Modular
IDK if this is relevant, but I use my voyagers in a very modular fashion with midi controls from my elektron Machinedrum. It's very crazy the stuff you can do with the two of them. Program change messages p'locked to steps in the sequence is rad, as well as real time recording filter/res/Osc levels is bad ass. For those of you who have both and are looking to check it out, remeber that you kit has to be saved with your ccv levels as they are in the voyager, if you dont, the next step triggered will either trigger from last known spot, or from "zero" which is the default position for ccv knobs. The MD does jump those knobs to what they are saved in the voyager as when patterns change, but if your kit isnt saved with the correct number, then you'll run into unexpected changes. Soemtimes its cool, but its worth pointing out.
Voyager Performer FR Revox2 Taurus3 mf;102,103,104zx2,105m,CP251x1 SEM Xpander 808 606 pro1x2 FR XS, FRorbx3 Modfactor timefactor space mopho PolyE Nord g1 Vermona drm mk3 KP3x2
