is there a way to categorise the presets in the banks on the voyager? So say i'm searching for a bass i could just scroll through all basses together?
Im sure i read something similar in the manual but i can't see it now.
thanks for any help and suggestions
categorising presets
Re: categorising presets
There is no search or filter function for the categories available.
This is just a simple information when scrolling through the sounds.
From the newest manual version (3.5), page 61:
http://www.moogmusic.com/products/minim ... nloads-tab
The manual is available here:SOUND CATEGORY allows you to assign the current preset to one of 32 pre-defined sound categories. This function is intended to assist in organizing presets for quick identification when auditioning sounds. This is especially useful in conjunction with the Voyager Editor/Librarian software.
Sequence:
Sequence:
Hmmmm so I can't organise my presets by category?
This seems so bizarre. In any other synth all 'bass' are together, all 'lead' are together etc
Do I have to buy the library editor to do this?
Remember, that the first hardware revision of the Voyager had only 128 presets. And there was no other true analog synth with patch memory and categories on the market then.
The seven sound banks were introduced with rev. 3 hardware and software version 3.0.
The SoundTower editor is able to sort them by category.
Sequence:
Sequence:
- misterpete
If you have the latest* Voyager firmware update installed you can scroll through all the sounds in a category by pushing the two buttons under the LCD at the same time then hitting an arrow button right or left ~ check the update dox for actual key names & step-by-step method
* at least a few years old now, btw
Please Call Me, PETE
"Mr. Pete" at MuffWiggler |@petedako on Twitter
And whatever you do, don't give any of your hard earned cash to SoundTower. They have yet to produce a reliable product.
Stephen
Stephen
Over the holidays I sat down and went through all 800+ presets, and manually categorized any that seemed promising (wrote down in a notebook) by musical function (drones, leads, bass, bells, weird piano, etc.). Also noted which were responsive to velocity and aftertouch.
Thanks for the tip though about category browse on the Voyager (without using Soundtower). I'll probably make another pass through the presets to see if I can find something to use as a launching point for a duduk-like lead tone.
Great tip about scrolling through. I'd still like to keep all bass presets together, all leads together etc.
