Post
by Stuka » Fri Nov 01, 2013 2:50 pm
Actually -
That will work, but if you plan to you an expression pedal in the mix, it's best to use TRS (tip-ring-sleeve, 3-conductor) patch cables.
The MoogerFooger CV jacks are wired such that if a TS (tip-sleeve, 2-conductor) cable is used in any of the jacks, an expression pedal will not function.
See the "Technical information" section of the MF-102 manual.
FWIW, I generally use TS cables for my audio patch connections, and TRS cables for the CV connections.
I've also used TRS cables in the audio jacks, and it worked fine.
Randy
