Mooger Spring Reverb?
Hello everyone. I was wondering if anyone knows if there might be a mooger reverb pedal in the works? I am considering buying a demeter rv-1 to go along with my voyager and murf to keep it all analog. Anyone heard anything?
http://bigcitymusic.com/product.asp?cat=New&pid=1000393
The Vermona Reverb seems to be very good, check out the features:
Features
True analog spring reverb w/ Accutronics Type 9 tank
Modes: Spring Normal, Spring Reversed, Non-Spring Normal, Non-Spring Reversed
EQ: 2-Band equalizer (bass / treble)
Filter: 12dB Lowpass Filter with Resonance
Modulation: ATTACK - DECAY envelope generator (with repeat function) for modulating VCF and VCA; external CV source or volume pedal for CUTOFF frequency
Trigger: standard GATE inputs for envelope generator and CRASH; footswitch input for envelope generator and CRASH
Footswitch inputs: VCF ON, VCA ON, BYPASS
CRASH: "Crashes" the spring module
Features
yeah it looks cool, i'll get it one day maybe
if you have 3 104s you can make a good reverb sound (so i've been told by the article i'm about to mention), check out the sound on sound article (it's on the website) Creative Synthesis With Delays, in the synth secrets series. http://www.soundonsound.com/sos/may04/a ... ecrets.htm
