Question about how a patch was made
I have a Voyager and just picked up a sub phatty. I have a question about the 2nd patch in bank #1. This patch has a repeating pattern like an arpeggio. Since the sub phatty does not have an arpeggio, can anyone tell me how that pattern was created?
Joe
Joe
Re: Question about how a patch was made
It's a repeat on the filter envelope
How do you turn that repeat on and off? Also, that patch has movement so its not like a single note played over and over. Can you help me with how that is created?
Thanks for your time.
Joe
Joe
- Bald Eagle
Filter Envelope Repeat is a hidden parameter in Shift mode. Shift mode is documented starting on page 23 of the manual. You will have to enter Shift Mode first and then turn on Filter Envelope Repeat (page 30). Play around with the filter envelope generator and you will get a better idea of what's going.
From the manual ...
From the manual ...
When filter envelope repeat is enabled, then the delay, attack, hold, decay, and release stages will loop continuously for as long as the note is held. The shorter the envelope times, the faster the loop will repeat.
Fantastic! Thank you.
Do you know if they same thing can be done with a Voyager?
Thanks again
Joe
Thanks again
Joe
- Bald Eagle
It doesn't have it. Here is a thread that discusses it.
http://forum.moogmusic.com/viewtopic.php?f=2&t=19458
Another (easier) way to turn it on/off is with the Moog Sub Phatty Editor
And you can also use the Sub Phatty Editor to load the preset and see all the parameter settings, including the under-the-hood ones.
Thanks for the info everyone. I will do that!
My Voyager is at Moog now having some mods done. I wonder if it is possible to have the voyager modded somehow to allow for this? I will find out.
Thanks again.
Joe
Thanks again.
Joe
