Programming question
jrm1
Post by jrm1 » Mon Oct 14, 2013 9:58 am
I have this patch on my Voyager, Growing Lead (factory). If I keep a key pressed down and press a lower key, it jumps to the new note but if instead I press a higher key it doesn't jump to the new note. Can anyone tell me why?
kironmusic
Re: Programming question
Post by kironmusic » Mon Oct 14, 2013 10:26 am
Go to Edit Mode, find "Keyboard Modes" and change it to "Last Key" (I'm pretty sure it's in "Lower Key" mode right now).
fyvewytches
Post by fyvewytches » Mon Oct 14, 2013 11:11 am
Check the "Keyboard Mode" settings.
hth
Latest track, Dancing On The Ecliptic http://soundcloud.com/ianman/dancing-on ... iptic-demo
thealien666
Post by thealien666 » Mon Oct 14, 2013 12:29 pm
Keyboard mode can either be "Lower Key", "Higher Key", "Last Key", or "1 Key Only".
This is programmable per patch. This one, "Growing Lead", is obviously programmed with keyboard mode set to "Lower Key", which will give priority to the lowest key played.
You should also be aware of the "Trigger Mode", which offers "Single Trigger" or "Multi Trigger", which will select how the envelopes will behave. In single trigger mode, once a note has been depressed and is being held down, pressing another key will not re-trigger (re-open) the envelope.
A careful reading of the manual, in the "Edit Mode" section, will explain all this in detail.
Hope this helps.
jrm1
Post by jrm1 » Mon Oct 14, 2013 2:46 pm
Brilliant! Thanks for the explanation. Re manual my retailer still hasn't sent me one but it's true I should have scoured the PDF one! RTFM.
thealien666
Post by thealien666 » Mon Oct 14, 2013 6:09 pm
You're welcome.
Until you eventually receive your paperback copy, here's the link to the online one in pdf format (if you didn't have it already):
http://www.moogmusic.com/sites/default/ ... _combo.pdf
jrm1
Post by jrm1 » Tue Oct 15, 2013 5:28 am
Thanks again. This synth is quite unbelievable! Starting to get to grips with using OSC 3 as modulation. So powerful. Such a well written manual.
Post by EricK » Tue Oct 15, 2013 11:13 am
There is also this "Voyager Training DVD" that has been uploaded to youtube featuring Brian Kehew:
http://www.youtube.com/watch?v=Bfe9bHhSMNk
thealien666
Post by thealien666 » Tue Oct 15, 2013 1:40 pm
This is a direct link to the playlist that includes all the 6 parts. Unfortunately, the audio quality is rather poor. But, hey, it's free.
http://www.youtube.com/watch?v=Bfe9bHhS ... 76E71BE6C6
