Will the editors knobs change and follow when I physically turn the knobs on the hardware sub phatty?
RIght now I have the editor connected to the sub p. Any changes I make on the hardware doesnt change what is showing on the editor.
SubP Editor following Hardware Synth changes
Re: SubP Editor following Hardware Synth changes
Maybe you should try this : go to the "Prefs" and check if Midi IN channel is number 1. My editor (in standalone) doesn't work if not on Midi IN Channel 1.
Check this out and let us know
MOOG Memorymoog+, Sub 37, CP251, ROLAND SH-1, SH-2, SH-7, SH101, Juno 60, SVC350, TR808, SCI Prophet 5 Rev.3.1, KORG Mono/poly, KR55, OBERHEIM SEM, WALDORF Microwave 1, DSI Prophet 08 Desktop PE, BOSS DR-55, BassBot TT303, AKAI MPC1000 JJOS2XL.
So the editor will follow the changes that i make on the hardware? If I turn a knob on the sub p then it will show it turning on the editor?
Well, on my editor and SB, the knobs are only moving when the midi in is Chanel 1.
Maybe i'm not the only one so you should try this first and let us know.
That's how it works for me, yes. (Mac OS X 10.8.)enfermo wrote:So the editor will follow the changes that i make on the hardware? If I turn a knob on the sub p then it will show it turning on the editor?
thanks guys. I just wanted to make sure this was possible before i start fiddling around to making it work.
