MF107 with sequencer
miaz
Post by miaz » Thu Sep 19, 2013 2:56 pm
just picked up a Tecbug sequencer
( https://www.youtube.com/watch?v=erPKjbLFJ2c )
so, what do i plug where?
seq gate to 107 wave? seq cv to 107 freq?
heres a video with a MFB urzwerg, and that is the connection this person uses.
https://www.youtube.com/watch?v=YF51afk2Oys
i did this, but nothing. only time i get anything,
is when i plug seq gate to 107 audio in.
and then i obviously just get a bunch of spikes.
any help?
dr_floyd
Re: MF107 with sequencer
Post by dr_floyd » Thu Sep 19, 2013 3:25 pm
The simplest configuration is seq cv out to freqbox FREQ in. Then OSC OUT on the Freqbox to whatever is next - filter, etc. There is nothing coming out the AUDIO OUT because there is nothing going to AUDIO IN. Note that the OSC OUT is an EXTREMELY hot signal. In this config I think ENV and FM amount knobs won't do anything.
You can also run the OSC OUT directly into the AUDIO IN, and seq cv out to FREQ input as above. This way you can use ENV and FM.
Unless you have an EG or LFO, the seq gate won't do anything. The Freqbox has nothing that can be gated. In the Urzwerg video you linked, the Freqbox oscillator is free running - no envelope shape to gate.
ColorForm2113
Post by ColorForm2113 » Thu Sep 19, 2013 10:37 pm
I don't have a freqbox, but couldn't you plug the gate out from the sequence into the audio in of the freqbox, then cv out from sequencer to freq in and use the freqbox audio out which theoretically be gated?
miaz
Post by miaz » Fri Sep 20, 2013 12:59 am
dr_floyd wrote:The simplest configuration is seq cv out to freqbox FREQ in. Then OSC OUT on the Freqbox to whatever is next - filter, etc. There is nothing coming out the AUDIO OUT because there is nothing going to AUDIO IN. Note that the OSC OUT is an EXTREMELY hot signal. In this config I think ENV and FM amount knobs won't do anything.
thanks for your help, but just tried this out, and i get nothing.
you can hear the sequencer running, i get like thuds in the sound, when i connect it to FREQ in.
and weather i get gate or not, thats ok, i just want some melodies, free-running or not.
(but i do have both 101 and 103. and the 103 has LFO)
miaz
Post by miaz » Fri Sep 20, 2013 1:23 am
sorry all.
actually got it to work.
not really sure what i was doing earlier, and last night.
anyways, the sequencer has a Level knob, which basically determines the
space between the voltages (and also how high and low the go)
reckon they were out of range for the MF107 to pick up or something.
miaz
Post by miaz » Fri Sep 20, 2013 10:30 am
ColorForm2113 wrote:I don't have a freqbox, but couldn't you plug the gate out from the sequence into the audio in of the freqbox, then cv out from sequencer to freq in and use the freqbox audio out which theoretically be gated?
thats kinda what i was doing at first, but then i didnt get the CV from the sequencer to work.
anyways, ive got it to work now, so then my question is;
is it safe to send a gate signal to AUDIO IN on the freqbox?
i mean, mine is still running fine, so no harm done so far.
crystalhellpool
Post by crystalhellpool » Mon Oct 07, 2013 11:52 am
Get a cp 251 and attentuate the OSC out, anyone confirm that gate to audio in trick?
Post by EricK » Tue Oct 08, 2013 11:09 am
I wouldn't send the 107 a gate signal simply because there is nothing to trigger. Rather than triggering audio, you should just use the osc out and send that to a VCA and trigger it that way.
crystalhellpool
Post by crystalhellpool » Thu Oct 10, 2013 7:36 pm
Too bad they dont have a vca/eg fooger. Pretty stupid if you ask me. I usually just run the freqbox into a rogue
Vsyevolod
Post by Vsyevolod » Fri Oct 11, 2013 2:41 am
They do have a VCA Fooger. It's called a Ring Modulator. I use it as a VCA all the time.
Stephen
Alien8
Post by Alien8 » Fri Oct 11, 2013 9:30 am
Vsyevolod wrote:They do have a VCA Fooger. It's called a Ring Modulator. I use it as a VCA all the time.
Stephen
Sorry to hijack, but it is related - Can you point me to an example of how you set-up to do this?
Post by EricK » Sat Oct 12, 2013 12:49 am
You CAN use the 102 as a vca but you lose a lot of the great aspects of the 102 by forcing it to do that. It doesn't take the place of a real vca fooger.
Seek out the "Lord of the Ring Mod" document.
Vsyevolod
Post by Vsyevolod » Sat Oct 12, 2013 10:36 pm
EricK wrote:You CAN use the 102 as a vca but you lose a lot of the great aspects of the 102 by forcing it to do that.
That's why we all need two of them!
Stephen
David Smyth
Post by David Smyth » Wed Oct 16, 2013 10:39 pm
crystalhellpool wrote:Too bad they dont have a vca/eg fooger. Pretty stupid if you ask me. I usually just run the freqbox into a rogue
Check out the new Minifooger MF Boost Pedal. It has Expression (CV) control over gain. You'll need some other Envelope Generators though..
David.
NZ
Minimoog Voyager XL, Little Phatty Stage II + CV Output Mod, 2x Slim Phatty, Minitaur, MP-201, EP-2, 2x CP-251, MF-102, MF-104M, MF-107
