LP Stage 2 going crazy
Everything Phatty.
JanGeerts
Post by JanGeerts » Tue Jul 30, 2013 4:09 pm
Since rehearsal yesterday, it's doing weird things. Bad weird.
Without touching it, parameters change, especially the lfo rate seems to go all the way up, and sometimes notes hang, without having triggered one.
Anyone experienced this?
thanks
Jan
Re: LP Stage 2 going crazy
Post by Amos » Wed Jul 31, 2013 12:00 pm
make sure you aren't sending Midi Time Code (MTC) to the LP.
miamigroove
Post by miamigroove » Wed Aug 07, 2013 10:26 pm
Mine has done this on two occasions in different clubs. There is a known grounding issue that causes the power supply to lose its ground reference under certain conditions. Search the forum here & you will find more info on it. If you DIY, the fix is simple, you just have to solder an extra ground wire to the P/S connector. Mine hasn't done it lately but I will do the mod if I start gigging with it and post the results later.
