pot map: pressure and velocity to master volume
sharema
Post by sharema » Fri Aug 02, 2013 11:33 am
Hi all, i have a question about the pot map.
If i set pot map 1:
source: velocity att.
dest: master vol
direct: normal
amount: 50
and pot map 2:
source: pressure.
dest: master vol
direct: normal
amount: 50
i have the control active only on the pressure parameter. If i switch off the amount of pot map 2 the velocity works correctly. It works correctly even if i put pot map 2 destination to another parameter. So it is like the master volume can't support more than one control a time.
Is the behavior correct?
stiiiiiiive
Re: pot map: pressure and velocity to master volume
Post by stiiiiiiive » Fri Aug 02, 2013 2:42 pm
I think that eveytime you press a key, a pressure event is generated, which kind of cancels the velocity event. Pressure is continuous while velocity is instant...
sharema
Post by sharema » Sun Aug 04, 2013 7:06 am
ok thanks, i understand.
But shouldn't pressure events be generated after the trigger of the key and only if the pressure comes (isn't it for that it is called after-touch too?)?
I am asking because it would be a nice way to have full control on dynamics
salut
RL
Post by RL » Sun Aug 04, 2013 12:38 pm
Hi sharema,
for these things I'm using pot mapping 1 for the velocity attack and pot mapping 2-4 controls pressure for the volumes of oscillator 1, 2 and 3.
Have fun,
Rudi
http://www.moogmusic.de
