Hello.
I didn't loose connection theses last two days but have some serious problems:
- Release is ignoring all modification in Panel Mode. ( It's working for some preset but not all, and if I put it on a value in preset mode and after that going to Panel Mode it's the same value that I hear in Panel Mode, but no way to modify it in Panel mode.) (Happen in VST, Standalone Editor and with no connections to computer )
- When I go back to panel mode any of the knobs move in the Editor, they just stay as they were on the last preset selected before changing to Active Panel. (But its seems to sound as they where before ). ( Happen in Standalone & VST )
- With Start with Active Panel check in the VST and Editor, there is a conflict, Active Panel and a Preset are selected at starting.
- When I launch ableton with a starting project ( Which have a Channel for the SubP with already configured MIDI In OUT & Audio Input + VST ) sometime it send and receive midi from the SubPhatty before I did anything and make the VST do not recognize the SubP anymore and I just must reboot my computer and the SubP. I solve this issue by making a starting set without the settings concerning the configuration of the SubP.
I updated to 1.3.3 to see if a re flash would change something but it didn't change anything.
Gonna try to re flash later, spend too much time banging my head on the desk today -__-
Edit: I make 4-5 reflash downgrade to 1.2.9 no way to make release work, what is weird is that it works for some of the preset but not all. I try to move all the parameters no way to make it works, it just works during a short moment after moving the value of multidrive, thenI move again multidrive and it stop working again... Then no way to make it works
And I have stuill this Panel Mode problem. I'll try to make a some reflash tomorrow to see if it change something...
