LP + EHX Memory Toy
Everything Phatty.
IgorCristo
Re: LP + EHX Memory Toy
Post by IgorCristo » Sun Jun 23, 2013 10:53 am
You can also lower your volume... the line level can be too hot for some pedals. I have a Deluxe Memory Boy and I use my Phatty with a max. of 70% output volume.
The other thing is that the audio interface can also make this noise... try with other instruments too! :)
Moog Minimoog Voyager Performer Edition and Little Phatty Stage II | Elektron Analog Four and Analog Rytm | Mutable Instruments Ambika | Korg Minilogue
stiiiiiiive
Post by stiiiiiiive » Sun Jun 23, 2013 11:42 am
True.
Oh and delays delay even the noise so the more feedback you set the more noise you get.
Dapifer
Post by Dapifer » Mon Jun 24, 2013 8:43 am
Thanks and yea like it's not unbearable, adjusting the volume does help. Stiiive, do you mean not using an adapter as the power supply? It's the only pedal I'm using but it does share an adapter with other things.
stiiiiiiive
Post by stiiiiiiive » Mon Jun 24, 2013 9:42 am
I exactly mean that: using a PSU that is shared with others stuffs.
IgorCristo
Post by IgorCristo » Tue Jun 25, 2013 11:44 am
@Dapifer
This is how I'm using it... LP output volume at a maximum of 70% using a separate PSU adapter. No humming or any kind of noise... :)
Here's a video that I've made: http://www.youtube.com/watch?v=U0qM3n9UiYE
