little phatty modulation amount
Everything Phatty.
anselmi
Post by anselmi » Sun May 26, 2013 12:24 pm
I noticed my slim phatty let you set the initial modulation amount ans save it in the patch but in my friend´s little phatty you just set the maximum amount of wheel modulation
I was thinking about switch my slim phatty for a little phatty stage II with the expanded CV outs but this issue is a deal breaker for me. I want some patches to be recalled with an specific modulation amount and never touch it, but it seems to be impossible in the little phatty
Is there something I´m missing or this is the actual situation?
Sir Nose
Re: little phatty modulation amount
Post by Sir Nose » Mon May 27, 2013 5:42 am
On the LP, just keep the modwheel in the full up position. Use the front panel LFO amount to set depth that is saved with the patch.
I guess there could be some places where the functionality of the LP could be a problem. What are you doing where this would be a problem? Maybe there is an easy work around.
anselmi
Post by anselmi » Mon May 27, 2013 11:27 am
Sir Nose wrote:On the LP, just keep the modwheel in the full up position. Use the front panel LFO amount to set depth that is saved with the patch.
yep, I know this way
yes, in the slim phatty you can set an initial and final modulation amount
the way you described allows you to set just 1 level with another one that is always zero (mod wheel all the way down)
so you sacrify the possibility of having a pre-set modulation range of your choise in order to get an "initial" modulation amount by having the wheel all the way up...I don´t know if I´m explaining it right...
In my patches I like to set an initial mod amount aand also a final one, so when you move your wheel you reach a useful value...after all the possibility of having a modulation wheel scaling is just for this very reason, to limit the modulation range in a useful way, but when you sacrify it just to get the "static" modulation value that the patch should have (saved) you loose the modulation wheel purpose
