Sub Phatty additional hidden parameters issue
Everything Sub.
Bjornw
Post by Bjornw » Wed May 15, 2013 12:31 pm
In activate panel-mode. When turning power off for a long time it seems some hidden parameters go back to original values. I.E. filter envelope trigger mode. I want it to retrigger when playing legato. If I have to do these settings every time I start and use panel mode I don´t get that fast hands on, play and tweak but have to go through a bunch of hidden settings and then start playing. Anyone else had this problem?
Howard Scarr
Re: Sub Phatty additional hidden parameters issue
Post by Howard Scarr » Sat May 18, 2013 4:07 am
I noticed that active-panel mode often adopts hidden parameters from the previously selected preset (at least it seemed that way to me).
Also BTW, the saved mod wheel position isn't always applied when I load a preset (despite having set that behaviour in the global settings).
till
Post by till » Sat May 18, 2013 8:08 am
Howard Scarr wrote:...
Yes, I can recreate this by selecting three different patches in a different sequence. one patch will be with modwheel amount stored and the very same patch will be without if the other preset is selected before this one.
marty
Post by marty » Sat May 18, 2013 11:07 am
This happens to me too. Taking my Subby out on the road tomorrow for a first short little tour but thinking using presets for live performance is gonna be hairy until this is resolved.
Post by Amos » Tue May 21, 2013 4:37 pm
Hello all... some of these problems are definitely resolved in the current (beta) firmware, v1.2.1
(available here.)
If you are using the latest firmware and are still experiencing any of the above problems, please let me know as soon as possible. Thank you!
(firmware update instructions, if needed: http://forum.moogmusic.com/viewtopic.ph ... 15#p115528)
Howard Scarr
Post by Howard Scarr » Wed May 22, 2013 7:18 am
This one (at least) isn't fixed in the 1.2.1:
Me: "the saved mod wheel position isn't always applied when I load a preset (despite having set that behaviour in the global settings)."
misterpete
Post by misterpete » Wed May 22, 2013 12:57 pm
confirmed here... bummer ~ similar to the Taurus MOD Wheel issues ??? :(
I'm wondering if some other "Global" parameters aren't saved... ~ particularly VOLUME - which seems especially counterintuitive, defaulting to the preset volume
Please Call Me, PETE
Bandcamp & all the other platforms :D
Post by Amos » Wed May 22, 2013 5:59 pm
All right, let's try this one. I found a place where I might not have been updating the mod wheel amount correctly under some circumstances... thanks for checking it out:
http://www.moogconnect.net/downloads/su ... _1_2_2.syx
till
Post by till » Thu May 23, 2013 5:12 pm
The new firmware 1.2.2 helped!
The mod wheel value is now used according to the global modes.
