MC,
If this was used with the MFs, would it cause any damage?
http://www.wiard.com/1200/JAG/jag.html
A question for MC
A quick peek of the sequantizer manual (none for the jag) shows that their modules generate up to 10 volts. The MFs maximum input are 5 volts. There might be some damage if you try to put more than 5 volts into a MF. However a simple voltage divider can drop the 10 volt of the Wiard to 5 volts, all you need are a pair of like resistors (start with 4.7K) for each MF input. Google for voltage divider.
