I've also tried the Minitaur with Logic and noticed a few strange things happening with the LFO Rate.
During one session, turning the LFO Rate away from the minimum position caused the overall volume to drop drastically.
And in another session, moving the LFO Rate turned on the solo buttons on the first 3 tracks in Logic.
I'm guessing that the LFO Rate had somehow managed to get mapped to these functions but I have no idea how/when that could have happened.
I had been using the beta editor, which I think is connected to this issue.
Anyone else had a similar situation?
Richard
Minitaur: LFO Rate & Logic oddities
Re: Minitaur: LFO Rate & Logic oddities
Actually, in my case, LFO rate solo's the selected audio channel in logic...
Hope they will fix this in new firmware update...
You can sort this out in Logic by filtering MIDI messages. That's what I do and it works.
Eurorack, 5U, x0xb0x, Moog Slim Phatty, MF-102, MF-103, MF-108, CP-251, Beatstep Pro, Nord Lead 1, NI Maschine, MXR-104, ProCo RAT2, Big Muff π Bass, Logic Pro 9.
http://soundcloud.com/martianarts
"filtering MIDI messages"
I see no filter option in midi settings
Can you explain pleasenectarios wrote:You can sort this out in Logic by filtering MIDI messages. That's what I do and it works.
Settings>MIDI>Input Filter>then check the box Control Changes.
Done.
Done.
Thanks Nectarios!
