MIDI INTERFACE TO RECORD VIA PC??? MOOG LITTLE PHATTY
Everything Phatty.
Elotero001
Post by Elotero001 » Sun Apr 14, 2013 11:42 pm
HI, I HAVE THE MOOG LITTLE PHATTY AND I WANT TO RECORD TO MY MAC OS X, DID I NEED TO BUY A MIDI INTERFACE TO DO THAT?? WHICH EQUIPMENT DID I NEED TO BUY?? ANY HELP ITS OK!!!
aen
Re: MIDI INTERFACE TO RECORD VIA PC??? MOOG LITTLE PHATTY
Post by aen » Sun Apr 14, 2013 11:55 pm
To take full advantage of your phatty, I would suggest an audio interface. That way you can record the sounds your phatty makes. Many audio interfaces ship with audio and midi recording software, so you can control software with your phatty, in addition to tracking the phatty's audio signal. You don't exactly need a midi interface, because the LP has USB/midi capabilities.
You can also try Reaper for free (for a pretty long time, If I recall correctly) which is a pretty fully featured audio/midi DAW.
You can nab an audio interface for just about any budget these days. Enjoy!
also maybe LESS CAPSLOCK BECAUSE CAPSLOCK LOOKS RUDE TO SOME PEOPLE.
Elotero001
Post by Elotero001 » Mon Apr 15, 2013 12:10 am
hi, when i bought the little phatty the guy who sell it to me told me that the usb cable it's just only to send patches, but if you said that i can record with that, cool!!! so, reaper it's the software?? i have a mac os x so i need to try it, thanks !!!
Elotero001
Post by Elotero001 » Mon Apr 15, 2013 12:12 am
did i need only the usb?? or i need the audio interface also?? i have a macbook
aen
Post by aen » Mon Apr 15, 2013 10:11 am
You can use your Phatty's USB cable for MIDI. This means controlling software synths for most people. If you want to record the sounds your phatty makes, you have to have an audio interface.
Stuka
Post by Stuka » Mon Apr 15, 2013 1:05 pm
... and, if you haven't done it yet, you REALLY need to download the LP owners manual from the Moog website and dig in!!
Also, the following site has a lot of good information that distinguishes between MIDI and AUDIO, and the type of equipment that is required to work with each:
http://tweakheadz.com/how-to-get-starte ... ng-studio/
Keep in mind that if you start recording on your computer, you'll probably need to go to the forums for the specific software you decide to use to address specific "how to" questions. All DAW software is definitely NOT made the same!!!
With few exceptions, you'll find the USB port on most music equipment is to send & receive MIDI only, not audio.
MIDI can do a lot of things, but audio generally requires a separate connection.
Most of the Moog gear, and larger keyboards, controllers, sound modules, etc. from other manufacturers, will have both USB and DIN ports configured for MIDI, which gives you different options for using your gear with, or without, a computer in the mix.
I have heard of some people using the built-in "audio in" (microphone?) jack on a MAC or PC to record the audio from keyboards, mixers, etc., but in general you'll have MUCH better quality if you use a separate audio interface, whether it's separate external interface or dedicated card installed in your computer. The external audio interfaces generally WILL connect to your computer over USB.
Elotero001
Post by Elotero001 » Mon Apr 15, 2013 4:38 pm
Thanks for the answers!!!! now i understand more about midi and audio, well, so, i need to buy an audio interface, which audio interface do you recommend me ?? i have paypal and ebay account, which audio inteface it's recommended and can record the sounds of my moog little phatty???
thanks for all!!
Stuka
Post by Stuka » Mon Apr 15, 2013 5:57 pm
I'm not sure where you're from, but I strongly recommend you visit a local shop that sells computer-based recording equipment (like Guitar Center or similar shops in the US) and take the time to learn about different software and hardware options to use with your computer.
It sounds like you need some direction with both your Moog LP (which folks here can help you with), as well as a lot of tutoring on using your computer for recording music ~ for THAT one, you really need some hands-on help, and this probably isn't the best place for assistance.
Remember, you'll need to learn about both SOFTWARE and HARDWARE that is suitable for recording with your particular computer.
BTW -
Referring to some of your other threads, you really need to touch base on the forums that make the software, like Arturia; even though they have the "Moog" name attached to the software, they actually are NOT Moog software.
The only software instruments currently made by Moog are the Animoog and Filtatron apps made for iOS devices.
You have much to learn, so give it time ~ it should be a fun ride if you give it a chance! :)
