how to trigger envelopes with guitar?
kcabdeef
Post by kcabdeef » Thu Sep 08, 2005 6:19 pm
Hi!
I've been experimenting with the moog to amplify my guitar, but I'd like to be able to make the filter respond to the amplitude of the signal in a way that the envelopes get triggered whenever a note is played.
Now is there anything, some sort of noise gate I believe that has a CV gate output?
I think I can take the signal out of the insert and use it to feed such device.
Is this possible?
sir_dss
Post by sir_dss » Thu Sep 08, 2005 6:35 pm
Something like this would do the trick...
http://www.blacet.com/IO.html
I have one and when I run a guitat into the EXT In on my Voyager(filter) I can get all sorts of cool effects. It does take you into the world of modular synths too.
Maybe the Moogerfooger MF-101 too?
Cruel Hoax
Post by Cruel Hoax » Thu Sep 08, 2005 10:04 pm
The Moogerfooger filter pedal will give you envelope CV out, I believe. The Sherman Filterbank definitely will.
I was lucky enough to stumble upon a Filterbank, and I use it as a CV generator all the time.
-Hoax
kcabdeef
Post by kcabdeef » Fri Sep 09, 2005 1:11 am
thanks guys!
So can the MF-101 envelope be triggered by a determined signal level? (threshold)
and isn't there any other cheaper option?
:oops:
