My Slim Phatty has crashed
Everything Phatty.
svukotic
Post by svukotic » Sat Sep 15, 2012 5:08 am
Hi
I bought a used Slim Phatty and everything is working great, however when I connect to LOGIC PRO via USB and started to change presets created something like a loop and the display was written erised memory or RAM mostly after I left without electricity when I again turned SlimPhatty got only white screen and Moog is blocked and everything is blocked and when turning the knobs nothing happens.
Moog sound comes from that goes from very high frequency and downhill all the way right up to the low 40 Hz or lower, and after that there is no longer any sound.
Everything is repeated every time i turn on sinth.
When you connect it to the MacBook via USB macbook sees that it is connected.
Please help me to solve this problem, whether perhaps I need to buy a USB Debug Adapter from Silicon Labs and wipe the Phatty processor, whether it be for me to help you recover Phatty in order
Thanks for the response
S.
CTRLSHFT
Re: My Slim Phatty has crashed
Post by CTRLSHFT » Fri Oct 05, 2012 12:56 am
Definitely sounds like a midi feedback loop nerfed it. Have you tried a factory reset yet? I did that on mine for a similar issue and that fixed it. You might need to try a couple times if the initial attempt for reset fails, but it's a lot cheaper than getting a debugger.
www.ctrlshft.com
svukotic
Post by svukotic » Sat Oct 06, 2012 11:03 am
I dont try a factory reset because i don't now how
jeepo
Post by jeepo » Sun Oct 07, 2012 3:11 pm
http://www.moogmusic.com/sites/default/ ... manual.pdf
page 45 explains how it's done. If the display is not displaying anything, you'll need to count clicks to navigate the menus (I have the LP, so I can't tell you how many).
Stage II, MF-102, MF-105m, MF-107, paia theremin, akai s2000, yamaha pss 680, yamaha cp 25, and other stuff
svukotic
Post by svukotic » Mon Oct 08, 2012 4:59 am
:D :D :D
Please,how many clicks
jeepo
Post by jeepo » Mon Oct 08, 2012 12:21 pm
Moog tech support is very friendly. I'm sure if you call or email them they will help you get everything working as quickly as possible.
svukotic
Post by svukotic » Mon Oct 08, 2012 1:55 pm
Thanx!!!
jeepo wrote:http://www.moogmusic.com/sites/default/ ... manual.pdf
Voltor07
Post by Voltor07 » Tue Oct 09, 2012 10:17 pm
svukotic wrote::D :D :D
Someone who has the SLIM Phatty needs to tell you this. The LITTLE Phatty might have a different menu.
Sub 37 #000068, Minitaur, CP-251, MF-102&103, EHX #1 Echo, EHX Space Drums/Crash Pads, QSC GX-3, Miracle Pianos, Walking Stick ribbon controller, Synthutron.com, Lowrey Teenie Genie.
