Animoog 1.1.0 Bug
Animoog 1.1.0 Bug
Having a lot of fun exploring the CC mapping using automation.
One bug though: when Animoog runs in the background CC automation stops. When switching over to Genome sequencer to draw/tweak CC curves, Animoog stops responding to CC messages, though it keeps playing the sequence. I tried different CCs and different parameters on Animoog.
Would be nice to get CC feedback from Animoog while switched to background mode.
Bye, for now.
ps: loving the update, nonetheless!
Bye, for now.
Re: Animoog 1.1.0 Bug
switching back to animoog and having the DAW running (Beatmaker2 in my case) results in playing the CC automation, tho. still not the desired workflow when I want to make changes to patterns etc.
When changing categories sometimes presets are missing. Have to click on another category then back again 2 or 3 times before all appear.
Ipad1
ios5.1.1
No jailbreak
Ipad1
ios5.1.1
No jailbreak
Hi, on my iPad 1 the app does not start anymore, it suddenly crashes!!
It works ok on the iPhone 4
supersaw wrote:When changing categories sometimes presets are missing. Have to click on another category then back again 2 or 3 times before all appear.
Ipad1
ios5.1.1
No jailbreak
Is anyone else having this problem with presets temporarily missing?
In another thread there is the solution (that worked for me), you'll lose your presets though.geeklapeeno wrote:Hi, on my iPad 1 the app does not start anymore, it suddenly crashes!!
Delete Animoog from iPad,
got to iTunes and re-download the app
The Default Animoog Presets are now organized in folders. All the other presets are in the folder simply called "." first one on the list.supersaw wrote: Is anyone else having this problem with presets temporarily missing?
Hope that helps.
No, this is a problem when selecting a category. I sometimes only see 2 out of 10 presets (in my user folder for example, but it happens in others as well), sometimes see none, etc. I then have to tap on another category and then tap on the user category again. Sometimes all my presets will then show, but sometimes it is again not complete, so i do the same (tap on another cat. and then back) until they are all there.nuno wrote:The Default Animoog Presets are now organized in folders. All the other presets are in the folder simply called "." first one on the list.supersaw wrote: Is anyone else having this problem with presets temporarily missing?
Hope that helps.
I'm not sure if it is happening as often with the other categories because most have 20 to 100 in them so it's hard to tell without counting them all if they are all there. But i have noticed in some of my folders with 20 or less that there are some missing randomly. Again, i just click off and back on and eventually they show up.
Hmmm. Just checked and experienced the same. Hadn't noticed until now. Though I got the bug only on Animoog default folder EFX. At least so far.
I'd love to see this bug getting fixed in the next update as well.nuno wrote: One bug though: when Animoog runs in the background CC automation stops.
Best,
Whiteout
Solved! On Animoog 2.0nuno wrote:Having a lot of fun exploring the CC mapping using automation.
Bye, for now.
Sequencing from Phaedra and tweaking cc values with Animoog in the background.
Thank you Moog!
