Minitaur's knobs stop responding whenever USB is connected.
2re
Post by 2re » Sun Jul 08, 2012 12:50 pm
Hi all,
Whenever USB is connected, or when I use my Virus TI as a remote controller, the Minitaur's knobs stop responding. The only way to get the knobs working again, is to turn the Minitaur off and disconnect USB before turning it back on. I have the latest firmware (1.0.7), and it's been like this since I got it over two months ago. Am I the only one experiencing this?
RoboticEFX
Re: Minitaur's knobs stop responding whenever USB is connect
Post by RoboticEFX » Sun Jul 15, 2012 6:59 am
I replied with some issues I was having with the Minitaur, but apparently they didn't make to to the forum. I had the keys/knobs stop responding once, but I haven't had it happen again. I can't verify 100% if my usb was connected. I just had to unplug the power cord and plug it back in, and everything worked fine.
BezO
Post by BezO » Mon Aug 06, 2012 10:44 am
Similar problem here.
Mine is always connnected to my CPU via USB. I'll try without the USB connection to see if it makes a difference.
Not only will mine stop responding to the knobs, but it also loses the ability to play all but one note no matter which key I press on my controller. Disconnecting the power cable & USB was working until last night. No matter how many times I disconnected everything, I could still only get the one note and no response from the knobs.
But I don't believe I have the latest firmware as I'm having trouble installing it.
On a side note, I got a response from Moog regarding powering down. With no power switch, they suggest unplugging the unit. But I continue to see people refer to turning the Minitaur off. Are you unplugging it or is there another way to power down?
Moog Minitaur
iMac 3.6GHz 8-Core i9, 64GB RAM, OS 10.14.6
till
Post by till » Mon Aug 06, 2012 2:00 pm
BezO wrote:...Are you unplugging it or is there another way to power down?
Unplugging the at the mains or the power cable is the only way. You may add a little switch to the cable as a beginners DIY project. But only unplugging the "wall wart" will save energy perfectly when not used.
