As normal I cannot help myself but have a quick play when I get in there, to my horror the VPE was massively out of tune and the keyboard was not tracking well at all. I turned it off and thought I would look again the next day.
The problem was still there when I turned back on the following day. It had been left on for about 11 hours the previous day. This is England and it's summer so it rained for most of the time so the temp was only 15-16C outside and no heating on in the house so overheating shouldn't be a problem, all the other kit has stayed on many times for similar periods without problem.
I initially retuned all oscillators and their scaling, things didn't improve, but it did prove the oscillators are staying in tune and they are tracking the octave selection switch across the entire range 32' to 1'. I then played via MIDI and the weird scalling was still there. After checking the intervals i noticed the following, F2 to A#3 track okay. A#3 to B3 almost no change in pitch. B3 to C6 the tracking is almost exponetial in nature. One other strange feature, when pressing a note above B3 then below A#3 there is a 1-2 second delay before the Oscillator pitch changes (it steps after this time does not glide). All patches are fine Triggers, Filters, VCA's all working as they should be.
I have checked the CV coming from the digital board and the keyboard is generating linear 960mV per octave across the whole keyboard. However around the oscilator generator circuit I can see the problematic signal and I and guessing the oscillators are doing exactly what they are being told, the problem is somewhere between the CV input from the digital board and the CV input to the Oscillators.
I wasn't expecting to have to dig further into this machine for a while, but at least I will know just about every corner of this thing when I have finished!!!
