Win standalone 0.9.41 sound data lost on rename
i renamed a few sounds in the librarian. The renamed sounds were all reset to something like the init sound.
The first few sounds i had renamed in this session have been ok.
Thanks,
Is there a specific scenario you can provide which reproduces this issue ?
that may have been due to a temporary work-around (for a different problem) which is now fixed and working as it should in v0.9.42 –
can you confirm if you do / do not still have this problem with the newer version?
I tested renaming some user library sounds (presets which were not loaded in the hardware bank) and their sound was unchanged; this was using 0.9.42. Hoping you have the same experience. :slight_smile:
