This is my current dilemma as well…
I understand the technical differences and purist opinions aside pertaining to the way they work and play, there are lots of people that do need to integrate these moogs into a solid DAW environment and think more about complex patches with timed, integrated control.
In that case, the voyagers presets (for recall or saving accidental patches on your way to your goal patch) come in handy, the midi transmit from the knobs and controllers are priceless for automation and integration, and more complex routing and patching internally should yield some more complicated synthesis results…
The big question is!
Does the old school truly “feel” better sonically…
side by side with a voyager, the model D tends to project more, be edgier(ripping electronic quality) and cut thru(more presence) over the voyager.. yes they are different Instruments, and yes the voyagers features are way more dense in comparison, and you can probably process a voyager to give you a similar result.. but I’m referring to those nuances and things you mostly feel more than hear in similar patches between the two.
Does the OS have these qualities? If so, are they more pronounced than the voyagers and more like th older moogs and their “raw” ways?
or is it the same as the voyager just a subtle tonal difference that doesn’t encompass what I mentioned…
If they both hit just as hard equally, then the full blown voyager is 100% worth it, as your not gaining much by going for the scaled down voyager (other than purist players that are looking for that style of thinking of course).
But, if the OS does have something sound wise that takes it back to that older sound and reproduces some of those qualities more faithfully then it might be worth it to have BOTH in my case…LOL but id rather just get a voyager and a phatty II and call it a day.
would love to hear what Amos or anyone else thinks about these elusive qualities.
