Up until very recently I owned three Chromas… now I’m back down to just the one but it sits under my memorymoog and Voyager quite nicely and complements both moogs well.
I wouldn’t get rid of it as I haven’t been able to find another synth, either hardware or software that can replace it (please someone emulate the Chroma in software), and I would go as far as saying I would sell my memorymoog before getting rid of the chroma, in fact over the last 2 years I have sold my JP8a, Matrix12, OB8, CS60, Prophet 5 and Synthex all because in some way the Chroma can fit into this tonal range.
Sure, it has a digital control interface and yes there is just one slider but i have never found it a problem to press a button and then adjust the parameter . . all you new LP owners will get to grips with that idea shortly.
Yes there are problems with Chroma power supplies but no more then a CS80, prophet 5 or memorymoog… this is the nature of machines this cutting edge (for the time) and this old. Have the power supply rebuilt, which is quite cheap to do and the Chroma will power up each and every time and tune all 16 Oscillators in one go . . and it stays in tune! (compare that to an old moog).
There are chips inside a Chroma that can go wrong and some are even hard to find now but this is just the same as a memorymoog, OB-8 or synthex. Nine times out of ten a voice card can be brought back to life by changing all the 4XXX chips on the voicecard, replacement components are readily available at a very small cost.
Basically the Chroma is a polyphonic 2800… it’s even got limited modular capabilities as you can change the path of the audio/signal so yes it is diffecult to program but with a MIDI box attached it’s possible to upload banks of sounds very easily and there are 100’s of great programs freely available on rhodeschroma.com (big thanks to Chris Ryan).
In fact, there is a brand new retro-fitable computer board available right now that allows you to add another 150 patches (200 on board in total), 2 line 40 character LCD, midi mapping of all parameters and extra inbuilt MIDI, which will really add to the ease of programming the damn thing.
As for the sound . . playing the beautiful keyboard is a delight. Other then the SCi T8 (and Synclavier) there isn’t a better keyboard on a vintage synth. With pressure sensitivity and on some Chromas, poly aftertouch the sounds just ooze out with such expression… it’s a synth for real players.
I personally find the sound detailed, solid, sparkly and organic . . if you want fat squigy basslines then a moog is going to be better but if you are looking for a polysynth capable of great “comping” sounds and expresive “real-world” lead sounds then the Chroma is spot on . . there are a couple of string presets that just sound so much more expresive then any digital ROMpler I have played and the guitar sounds are very close to the real thing. Bell sounds are brilliant and as for Rhodes pianos . . funnily enough it does them extremely well too (probably the keyboard helps!).
Reading through this thread I find it hard to understand some of the comments made . . I do understand personal taste . . if you fundamentaly don’t like the sound of something you’ll never like it, so fare enough but to dismiss the Chroma without spending some time on a unit is just foolish.
The factory patches, like a lot of great synths are rubbish . . download all the patches of the Chroma website, get yourself a midi box and laptop and spend a few hours goping through them . . you’ll find you won’t have to do too much programming to get what you want.
Another great thing is that the Chroma sits really nicely in the mix, it’s clarity really cuts through - try it before you dismiss it.
Here’s the funny thing… it does have an industrial servo making a “thunk”. the switches are membranes so on a dark stage it’s sometimes hard to know if you have pressed a button, with the servo on you get tactile feedback…you naturally can turn it off!
My 2 that I recently sold will be up on rlmusic.co.uk shortly and just for dr_floyd . . heres a photo!
Mal
