Vx-351 + 352 DB-25 cables
Hi, I just bought both boxes for my Voyager RME and was wondering if anyone here knows a place where to buy new DB-25 cables, but with a flat plug?
The DB-25 plugs on the boxes itself are on a inconvenient place. When the cables are plugged in they hinder the operation of the knobs and in/outputs behind them because they stick out so far. :frowning:
I am pretty sure there are cables where the chord is in a 90 degrees angle with the actual plug, but I can not find them. Does anyone know?
Thanks, Boele
Couldn’t come up with a cable like you would like to have, but put this in the search engine of your choice:
Low Profile Right Angle Adapter, DB25 Male / Female, Cable Exit 3
You have to watch out for the correct cable exit though, so the cable would actually go towards the edge of the VX and not over the jacks/pots.
Hope this helps.
You want “Exit 2” not “Exit 3” to send the cord away from the unit. Like this:
http://www.l-com.com/item.aspx?id=8814
Stephen
